Sep 22, 2012 #1 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 02 714 af 05 lb 33 bat 13.7 ine 128 bl 124 mph 0 temp 173 aes 126 rpm 875 tps .42 iac 25 cc 05 codes 0
Sep 22, 2012 #2 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 SIXBANGR said: 02 714 af 05 lb 33 bat 13.7 ine 128 bl 124 mph 0 temp 173 aes 126 rpm 875 tps .42 iac 25 cc 05 codes 0 Click to expand... When i push the recall, the screen goes blank except for the dot. Was fine befor. I put my iat in the intake, and put on a HD wastegate. Now i get knock with my normal 25lbs of boost w/alky.
Sep 22, 2012 #3 8 87-WE2 Back in business!! Joined May 17, 2011 Messages 1,132 You're good. If you haven't gone wot, your recall has no info stored and will display as you described.
Sep 22, 2012 #4 8 87-WE2 Back in business!! Joined May 17, 2011 Messages 1,132 87-WE2 said: You're good. If you haven't gone wot, your recall has no info stored and will display as you described. Click to expand... Sorry. I hit send too quick. I dont know why youd get kr now after the wg. The sm is working ok though. I need to proofread my responses before i hit send.
Sep 22, 2012 #5 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 you are correct. I was backing out of it because of the knock
Sep 22, 2012 #6 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 SIXBANGR said: Was fine befor. I put my iat in the intake, and put on a HD wastegate. Now i get knock with my normal 25lbs of boost w/alky. Click to expand... Your boost is probably coming up faster with the HD wastegate actuator.
Sep 22, 2012 #7 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 mikestertwo said: Your boost is probably coming up faster with the HD wastegate actuator. Click to expand... turns out my alky was not turning on. The vacuum line to the map was broken.
Sep 22, 2012 #8 W we4Mateo Double you eee what? Joined Apr 7, 2010 Messages 4,381 SIXBANGR said: turns out my alky was not turning on. The vacuum line to the map was broken. Click to expand... You're lucky it wasn't worse...
