scanmaster #'s and a ?
SIXBANGR
mean old man
02 714
af 05
lb 33
bat 13.7
ine 128
bl 124
mph 0
temp 173
aes 126
rpm 875
tps .42
iac 25
cc 05
codes 0
02 714
af 05
lb 33
bat 13.7
ine 128
bl 124
mph 0
temp 173
aes 126
rpm 875
tps .42
iac 25
cc 05
codes 0
When i push the recall, the screen goes blank except for the dot. Was fine befor. I put my iat in the intake, and put on a HD wastegate. Now i get knock with my normal 25lbs of boost w/alky.
You're good. If you haven't gone wot, your recall has no info stored and will display as you described.
Sorry. I hit send too quick. I dont know why youd get kr now after the wg.
The sm is working ok though. I need to proofread my responses before i hit send.
