mitchell.cox1
The "Z"
- Apr 22, 2010
I know i cant do much till I get my tt chip in...Now i have a couple other chips but not burned for my exact setup, which is
injectors-bluetop 36#
turbo- precision 60mm
intercooler-really big external fan
torque converter- ? about 2200-2300 stall, not stock
cylinder heads- stock
camshaft-210-218
I got a scanmaster and put a regular chip in it here are the readings
02mil-402
af-04
l8-43
bl-128
clt-95
ats-99
rpm-800
tps-44
iac-27
cc-70
mal-0
Now i just replaced both my headers and cleaned everything up, new vac lines cleaned up the turbo and installed sm. before when i got it it was "loping" so i did some investigation and my ds header was leaking, and there were many other leaks, now how do i change certain settings that are too high or too low?
camshaft-210-218
02mil-402
af-04
l8-43
bl-128
clt-95
ats-99
rpm-800
tps-44
iac-27
cc-70
mal-0
