Picked up a non running project from a semi local guy. The car has been sitting for years, seller stated he was driving it and it just died. He got tired of throwing money at it and decided to sell. My friend and I simply asked, how much if we bring a trailer and don't ask you a bunch of questions. He shot out a number and we accepted. Here's a few pics, wow, what a mess of wiring. Fella loved butt connectors. Took a few days but we ran down probably the worse of the worse no start conditions. Everything was a problem, the car failed the very first no start test. The check engine light would not respond.
I'll make a long story short.
2 broken ECU wires under dash, yes, butt connectors.
Aftermarket ign coil with caspers cam sensor cap = problem
Bad coil
Bad crank sensor
plugged fuel injectors
Green corroded connections at ign module and pretty much everywhere
And the standard plugs, wires, oil, filter, trans flush, valve springs, big order from Full Throttle etc etc.
Toilet plumbing for cold air intake
We also picked up a turbo dash cluster for '78 and some T-Type wheels.
Here's a couple of pics and a short video, if this works. Pics are out of order, but as you can see on my scanner, no codes present!
There's still a lot of wire soldering and clean up to do, but it's turning out nice. A friend stopped by my shop and wants to buy it. Going to be tough to sell, I live it!
And the video of start up
Bad coil
Bad crank sensor
