SD2 Closed Loop Box
5280GN
I am having an issue with my car staying in closed loop at idle. The check mark in the closed loop box flashes and intermittently drops out. I checked all connections and they are good and clean. Any ideas?
Check TPS voltage at idle. Is it in a good range for low idle? .42-.44volts?
Good idea I'll check the tps voltage. I think it was a little low at .40
Check TPS voltage at idle. Is it in a good range for low idle? .42-.44volts? One of the idle entry conditions like that might be kicking in and out
looks like the board has been "fixed" again.
Bob
the board needs the ads in order to exist, thats no big deal. The multiple postings are likely a configuration error. Every time something gets changed it takes a little while to shake out the bugs. I think Jay is off work at the moment, so it may be a little while.
Bob
