The "Spring Cleaning" routine from GNTTYPE.org says:
"It's a good idea to use JB Weld or black RTV to seal the edge of the filter where the metal part meets the plastic. Seal all around the edge and MAKE SURE THAT IT IS COMPLETELY DRY before reinstalling. This helps prevent aereation of the fluid under hard acceleration."
In another tech article on the same site, a different author warns to NOT use RTV around the pan gasket surface as it can destroy the trans itself if let inside. Is this where the "make sure it is completely dry" disclaimer comes in?
What gives?
Is it wise to seal the edges of the filter with black RTV or not?
What gives?
