I HAVE reused them, BUT.......for less than $30 you KNOW it'll seal. (assuming that you didn't deck the block or heads too much and you are using the stock head gaskets) If you milled the block, heads and are using thinner head gaskets, you gonna have to TRIG things out. (TRIG = triginometry- measure things carefully and have the manifold cut, or it WILL leak.)
