Searching for a rocker cover bolt - not the ordinary ones!
Hot Air Beast
Hot Air Lover
Can anyone offer a suggestion as to where I can find the outside rear rocker cover bolt on the drivers side? It is the same length as the others but the last 3/4 inch or so is a six sided, pressed on spacer with a threaded shaft extending from the top, to which an 8mm nut is affixed. This holds the vacuum controller in place. No big deal but it has been broken for a long time and it would be nice to find a replacement. Right no I am using another bolt with two nuts and a washer as a spacer to replace the six sided pressed on spacer.
If I haven't described this bolt well enough I will take a pic and post it.
Phil
Does it look like this?
Thanks guys - I have pm'd Brad
It's a pain being in Canada, when stuff needs to be sent cross border. Gave Brad some options. Am OK with jury rigged solution for now.
Phil from Canada
