Seat back adjustment
GSX-PKV
Through the years, my drivers seat back has "adjusted" itself to be leaning slightly back. It's not too bad but I was wondering if anyone has any advice how to adjust it so it is more upright. Thanks! Paul
Back from the dead! Anyone figure out the right way to fix the driver seatback yet? I'm losing weight but need to fix the damage that's done...:eek:
If it's not bent too far,fold the seat back forward,get in the back seat and try to put you weight into it and bend it back.If you are too big to do this pull the seat out and do it.
Does this really work without hurting anything???
DEPENDING HOW FAR BACK THE FRAME IS BENT,OR WEAKENED . SOMETIMES YOU CAN LOOSEN THE 2 REAR SEAT NUTS,PUT A FEW FLAT WASHERS BETWEEN THE STUDS AND THE BOTTOM SEAT FRAME, THIS WILL BRING THE SEAT BACK FOWARD.I'VE SEEN SOME GM CARS WITH AS SIMILAR SPACER IN SOME CASES..
