texasturbo
- Jun 25, 2001
I just had my engine freshened up with new bore job, pistons, rings, cam, bearings, valve springs, all that good stuff. I still have one cylinder that gets the threads wet with oil up to the seat of the spark plug. The engine now has about 600 miles on it. When I first started the motor I broken in the cam and lifters and then as I drove it, I would not beat on it, but drive around in third gear at a decent speed, and put a 190 thermostat in it to make sure the engine was good and hot for the new rings( it never overheated). I have not put more than 15 lbs of boost in it ( very very short burst when I did). The pistons were speedpro cast turbo pistons/ with moly rings(part # e-434k). Anyone else had this problem? Any thoughts on a solution?? Thanks in advance...
P.S. for the break in I put everything back stock on the engine,(turbo, fresh injectors, chip, intercooler etc. etc.).
