Several companies out there like ZZP, Milzys, Intense and others will sell you a pcm with a special tune. They flash the stock tune and install the custom tune along with your vin number. You can't just take a pcm out of one car and use it in another one like the old days with out reflashing it and re installing the vin number for the car that you are using it in. The car's security system however has to "relearn" the new pcm even though it has the proper vin installed. This "relearn procedure" allows the pcm to comunicate with the security computer in your car. With out following the relearn procedure the security computer thinks someone is trying to hotwire the car and it will not allow it to start. It is something like: turn the key to the start position for 10 seconds, let it fall back to the on position wait for 10 minutes repeat this for 3 or 4 times and on the last try it is supposed to start (if you have done it correctly). I just want to make sure I have the proper instructions before I try it.
