I would build this in a stage 2 block. I would also reconsider the compression ratio. You can get it done around 22-23psi with everything in place. Dont scrimp on the converter. HV pumps are overkill most of the time but id run one with those clearances.
Maybe I'll do a stage block in the future but I want to do a stock block. I should clairify that I just want the bottom end components/setup capable of touching the nines (For future combination changes and a little extra head room). This car will be setup to run mid to low tens.
About the oiling, I was thinking that too. Will the T/A Pump Cover really compensate for the larger bearing clearances? I would think with this extra flow & volume using stock pump would cause pressure to drop below it's already low idle pressure.
