I have a 94 Z28 with SpeedPro that I have somewhat tuned, at least good enough to cruise around in. I was at a car show waiting to get out onto the street, idleing for about 30 minutes, when the car starts to Idle at about 1500 rpm for about 5 seconds, then it drops to about 500 rpm and about dies. I didn't have my laptop hooked up to the SpeedPro to see what was going on, but I just gave the car a little gas to keep it running. Finally I got out on the steet and gave it quite a bit of gas to do a burnout and it seemed like the throttle was stuck at 4000 rpm. I pulled off the side of the road, turned the car off, jumped out and check the throttle and it wasn't stuck at all, jumped back in the car and it started up and idled okay. I finally got the laptop hooked up to the car and I noticed that the speedpro is not applying any corrections, it is like the car is running in open loop. I have tried to reload the tuning program again, clicked the run in closed loop button off and on again, and nothing happens. I know the car is now running very rich, could I have fouled the o2 sensor??? If so, can you clean it?? Any other suggestions as to what might be going on?? All the other sensors are working fine, just no corrections to the AF ratios. Any help will be appreciated.
Kevin Thompson
Kevin Thompson
