V
VPREATR
Guest
Has anyone interfaced an Accel VIC with a Speed Density SEFI8LO? The reason I'm asking, is to obtain individual cylinder control a sequential upgrade is needed on the SEFI8LO. Using the VIC would provide individual cylinder control (25% fuel trim) without the required SEFI8LO software upgrade.
Now upgrading to a sequential normally wouldn't be a problem, but in Optispark driven vehicles; only one company offered the ability to convert the resolution signals into Cam/Crank signals the SEFI8LO could use in SEFI mode. (Bothwell Automotive) Unfortunately that harness is no longer available (Lynkx), nor was it reasonable in cost.
Next option would be modifying the Optispark to drive a cam signal only and use a crank trigger in concert; however using a crank trigger on the LTx cars hasn’t been painless nor does it function mounting-wise in a blower driven setup. It may even be possible to use the eDIST and drive LS1 coils using the Optispark as a cam position sensor; however a crank signal issue remains. The key is to obtain even a minimal approach to individual cylinder control.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
