Sensor/CRS......
Chuck Leeper
Toxic old bastard
Staff member
Guess I've had too much time , since my last PUICK V-sicks....CRS has set in....
Trying to get the damn cam sensor set right, and am about out of brain cells... Wait, that may be the problem to start with!:mad:
Engine attempts starting, chugs for a few secs, then sneezes like it's backing up, dies.
I think I am installing the sensor the correct way, but 180* out.
I have a remote start button, roll it over til I get a puff out of #1, using the hose off the leak down tester.
Check the balancer, it's near TDC, so I roll it by hand to 25* ATD, use the install method we used in 2004. {Haven't done 1 since} :depressed: Dot on the gear pointed at the pass fender, the cap wires pointed to the dr headlite. Used the Caspers box. Lite worked as it should.
I pulled the dr valve cover, and as I bumped to TDC, and then rolled it by hand to 25*A, I see the exhaust valve beginning to open.
My instincts say this is the wrong phase of the cycle. I think this is the exh stroke, not the beginning of the power stroke.
This is a stock engine/cam, valve train. I put a new chain on it, and resealed it.
Someone set me straight, plse, before this ends up on the bag...:banghead:
you are correct the exhaust valve should not be opening at that point...was this a multi key cam gear set?
IF you are truly seeing the exhaust valve beginning to open at 25* atdc regardless what stroke it is on I think you have a bigger problem.....The exhaust valve should begin to open near the bottom of the power stroke say the last 30* or so.......sounds like your exhaust event is about 120* ahead of schedule to me.......
Yep.! Time to take it back down, And see wtf is going on.
A damn shame, too. I have been doing engines for 50 yrs, and can't get it right.:mad:
To boot, this was on an engine stand.:rolleyes:
Exactly.. I went back to the shop, and tried it 3 more times...Always finding the the exh valve early.
Another wasted day or two..Good thing is, I'm retired, so when I get fed up, I just close the shop, and go to my part time job as Walmart hottie inspector!!:smuggrin:
Thanks for the response. I had started dis assembly, but thot why not run it by someone else.
Ha ha, chuck you must have a much better walmart than we have around here !
At 76, one doesn't get near as "choosy" ...:jawdrop:
CRS has it's advantages, too. I don't remember the real scary encounters at Wallyworld, long enuf to tell my other 70 y/o buds about them...They have their own "exciting moments".
Sounds like what I did a while ago when I somehow installed the chain on the cam gear 180 out, I was younger so age shouldn't have been an issue more like transient sudden onset retardation..
There you go Chuck, you just proved the "value of this board!" Now wait till I tell my wife why being on this board is so valuable!...........I now have proof.............where was I going w/this????????
Got it apart, and compared the original single key lower gear on the crank, along w/ the multi key unit. looks like the cam is advanced quite some distance.
I had the engine at TDC, put the chain back on to match the original, [near new], gear set.
Going to re-assemble tomorrow.
More later..
