- May 28, 2001
Guess I've had too much time , since my last PUICK V-sicks....CRS has set in....
Trying to get the damn cam sensor set right, and am about out of brain cells... Wait, that may be the problem to start with!
Engine attempts starting, chugs for a few secs, then sneezes like it's backing up, dies.
I think I am installing the sensor the correct way, but 180* out.
I have a remote start button, roll it over til I get a puff out of #1, using the hose off the leak down tester.
Check the balancer, it's near TDC, so I roll it by hand to 25* ATD, use the install method we used in 2004. {Haven't done 1 since}
Dot on the gear pointed at the pass fender, the cap wires pointed to the dr headlite. Used the Caspers box. Lite worked as it should.
I pulled the dr valve cover, and as I bumped to TDC, and then rolled it by hand to 25*A, I see the exhaust valve beginning to open.
My instincts say this is the wrong phase of the cycle. I think this is the exh stroke, not the beginning of the power stroke.
This is a stock engine/cam, valve train. I put a new chain on it, and resealed it.
Someone set me straight, plse, before this ends up on the bag...
