GBGN1
BP Performance Transmissions LLC
- May 26, 2001
The OP (me) is not using a 200 trans with a SII PCM. I am using a SII PCM with the 4L60E, and we have been since day 1. This had been running over 500whp on the 4L60E with no issues the entire time, likely over 600whp now. Since the 500whp dyno runs, I have switched many items up. E85, 6266, External 3.5" dp, entire fuel system...etc. The only issue with the trans I have had is the Precision single disc LU TC, which was not built for the power it is seeing. I now have a 5 disc billet TC, but Precision is working on fabricating a one off input shaft to avoid any possible problems before we install. Im not sure how much power you plan on running daily, but the 4L60E has not let me down in 6yrs with very high power level. When they are built correctly, I wouldnt worry much about them. That being said, there are plenty of other options that have been discussed.
I will hopefully get a chance this year to sit down and update the thread with some newer info and results. Had a lot of changes/trials going on the last two years, but it is still running strong. Looking to get some more dyno time this year, as well as get it back to the track for a single pass and get the boot.
Cody
You getting a billet front shaft made for your 60* 4l60e trans?
