Serious 109 motor wanted........
Cheeseburger
I can build my own but maybe someone has one that is built allready!
I have a motor to trade so you will not be stuck without a motor.
Looking for a girdled,steel crank/rod motor.
p.m. me with what you have.
Thanks.
i have a 040"motor with forged pistons ,balanced crank and rods 206 206 cam new oil pump timing chain with 5000 miles.runs perfect 80 psi oil pressure at wot.no smoke no bull.excellent motor.stock heads with valve springs that match cam,new flywheel water pump etc.want steel caps.ill pull it apart and machine it.caps on shelf
Thanks for the offer, i guess i should have been more specific.
109 motor steel caps and or girdle.
Oliver rods.
Steel crank.
Forged pistons.
Aluminium heads or stage 1 iron heads.
Headers to work with a 3.5'' downpipe.
This is more or less what i am after.
I have a motor that ran mid 10s that i can trade towards this so you will not be out a motor.
May also consider a stage motor.
Looking for a good deal, otherwise i can build my own.
Just thought i would ask around incase someone is having second thoughts or ran out of money and wants to make a few bucks and still have a motor.
Thanks!
