service vech, anti lock, trac off lights all on
tpsecret6
Diagnostics tool was reading left rear wheel sensor 0 mph as i drove down the road all the others matched correct speed i was going...replaced left rear hub assy with new sensor drove it, lights didnt go out,then cleared all codes with the scanner, it went out for about 2 sec so lights r still on and left rear still reads 0 mph also every fuse on the pass side that has anything to do with abs is good! anyone had this prob b4?
Check where the terminals are crimped to the wires. The wires can be broken inside at the crimps but the insulation looks perfect.
To make sure you got a good sensor, you can connect a voltmeter set on AC voltage to the sensor, and spin the tire. The AC voltage should change with the speed of the tire. There's also a resistence vakue for a good sensor, but I don't recall what it is.
k thanks thats a good start i'll throw it on a hoist today and take a closer look
