TurboSlacker
SINISTR
- May 29, 2001
Help me understand this better...
If I take remove the cam sensor and reinstall it with the window point near the same direction when removed and the housing near the same oreintation when removed, the car should start fine, right ?
When I did this R&R my timing was off and the engine didn't turnover in a healthy way. So I set it the long way by putting the #1 piston at TDC, then placed the cam sensor window appx 4 o'clock pointing to the front-d/s, then rotated the housing to see the voltage drop from appx 7 volts to near zero. Engine fired right up.
Great, but I don't understand why I couldn't simply reinstall the cam sensor close enough since the only purpose of the cam sensor is to tell the ECM when the engine is positioned at compression stroke on #1 cylinder. The crank sensor should be telling the ECM precisely when to fire the ignition, not the cam sensor.
