No need to use a volt meter. Just make sure you are reaching over 80% at WOT, set the idle screw so you have the IAC where you want it, then go to idle parameters and set the maximum TPS for idle. I prefer to have the idle TPS around 12% and WOT as high as it will go, but it isn't critical.
