Shakedown Pass 1/8 mile
Your 1/4 Mile ET is 11.22 seconds computed from your vehicle 1/8th ET of 7.13 seconds.
Your 1/4 Mile MPH is 118.28 MPH computed from your vehicle 1/8th MPH of 95.39 MPH.
Just a note:
AFR on last pass was 11.6-11.7 and it turned the best time.
AFR on the first two were 11.0-11.2
I dont have AFR correction on. I need to send the chip back in for more fuel.
Nice passes! I wonder what that car's going to do when you put some boost in it?
11's on the brakes is pretty fast.
Good job.
Good job.
Thanks Brett!
I just bought tires yesterday. I will call you next time I go.
I have had to car to 23psi on the street and its brutal. That was 93/alky tho. My E85 chip needs way more fuel, Otherwise I would have had boost to 23psi on those passes. I really dont know what it will run. I need a 1/4 mile pass to see exactly where my MPH is at. Im hoping for 25-26 and maybe 28 with a locked converter.
If I had a PTC, I bet times would be even better. Anyway, big tires along with skinnies are going on next week.
Just a note:
Were you getting any kr on any runs?
All my runs had transitional KR of 2-3° from shifting. I put it in OD and jabbed the throttle once and got 15° on the last pass
What were your nb readings when the WB was showing 11.2-11.3, and also 11.6-11.7?
Tire combo looks nice! Have you had it on the street yet? Rear tires look awesome but real tight.
