shift points?
turbogimp
i am having my tranny built and need to know what the best RPM to have the shift points set at. so i can let my tranny guy know. thanks in advance.
What trans are you using? Still the 200R4? I'm no expert but I think the shift points are adjustable through the TV cable linkage near the upper plenum. The PROM also plays a part in Trans operation, however it may not do more than control converter lockup speed (if you have a lockup converter), I'm not exactly sure. Hope this helps some.
Eric
I'm sorry, with children, a wife and a job i kind of forget to add things from time to time. yes I'm still using the 200r4. well i was just told to get as much info on my car so he can build it. he wants cam specs, horsepower, ET, peak RPM. so figured i would give him everything i possibly can. i have an 1984 and he is building me the same tranny that he did for my friends 1987 GN that is running 10.90's in the 1/4. my car isnt running even close to that so i figure that it will last a long time (in theory). any other help is greatly appreciated. thanks in advance
