Hello all,
It has been awhile since I have been on the board. I will be rebuilding my engine again due to possible rod or main bearing gave out. Thought it would be my last rebuilt(2001) Never been to the track, before this happen on a few hard accelerations and saw alot of black smoke from the tailpipe from the rear view mirror. I heard a loud knocking noise, gets louder as rpm goes up. Sounded like it is ready to go through the oil pan. As I accelerate to move something gave and the engine seized. Engine will not turn over. I need reliable parts recommendation for my rebuilt supporting up to 500 HP max.
Hydraulic roller cam & roller lifters (that do not require adjustments), timing chain set, valve springs, head gaskets that do not requires retorque), pistons, rings, main & rod bearings, stock crank or steel crank from TR custom,
connecting rods and which engine block that is problem free (cam lobes?)part
numbers needed if possible.
Thanks in advance
My setup now: TE51, 42# inj., CAS FMIC, 70mm TB, 194/204 Speedpro cam,
TRW L2481 .030 pistons, steel main center caps, 2800 stall Vigilante
Thanks in advance
