TURBOELKY
- Jun 27, 2005
I have summit polyurethane bushings installed but haven't driven the car yet. Wish I was more help.
SignUp Now!I have energy suspension and. I also have poly bushings throughout the suspension components and poly motor and tranny mounts. I use amsoil synthetic grease for everything and have zero squekes or rattles other than Windows when they are down. I did notice some vibration in floor pan after the poly transmission mount was installed but I think some of that is my factory driveshaft is out of balance. Find out once I install the cromoly. Other than that it's smooth so I'm at a loss as to all these reports of issues people have. I will also say I can dial in my shocks and I don't have them super stiff but firm. I'm sure of i turned them up it would be a harsh ride. For those with varishocks I'm running setting 7 front and 5 back on single adjustable. I also don't have low profile tires so that could be a lot of it too.Were these Prothane poly's? I've read the Prothane's are slightly softer than the Energy Suspension poly's.
jdpolzin has used these. PM him for his thoughts.
I had 1 set, ONE TIME, sent them back. These were on my 86 GN. 1- 25 mi drive, my hands, and the cheeks of my butt were numb.that only TTA folks get annoyed by HR motor mounts
"Delayed body roll" sometimes means that while one portion of the suspension system was changed for expected improvement, an unmatched or "weaker" link in the system has materialized somewhere else.Alrighty all, I finally got around to swapping the Energy Suspension bushings for rubber. Well...my GN is back to being a Buick.
Short story...it went from feeling like a '80's F Body to being a G Body again.
Long Story:
The goods are that it solved the vibration I felt, as well as whatever subsonic resonance that was drowning out my subwoofers. Also, it is not nearly so jarring when I am on rough roads or hit hard bumps. The rubber body mounts really absorb that. I really didn't mind the stiffness though. I actually liked it. I didn't like the vibration or resonance. Not that I could hear it, but when a pair of 10" subs are instantly muted when you start the engine, it is just odd. I also don't have the squeaks in the t tops that I used to. It still does not feel like a stock TR since the suspension and motor / trans mounts are poly or solid, but it helps.
The downside is that it feels a little floaty again and I'd mot a fan. I really did like some of the unibody like feel about it. Also, I feel this delayed body roll when I turn hard and it feels sloppy to me. I'm sure that some fender braces and reinstalling my joust bars will help a bit.
In the end, I'd say I prefer the rubber body mounts for a car that is going to mostly cruise or be on street duty. If my main goal was to auto-x or roadrace this car, I'd go with the energy suspension mounts in a heartbeat.
Hope this helps you all trying to make a decision.
Send me the body bushings you took out and I will properly dispose of them....thanks
I had the same issue. Need to loosen the nut, I know that sounds crazy but Ramey told me to do so. It fixed it.I put in Kirban's rubber body mounts/bushings and that was the best $45 investment I have made on my car. I have HR rear sway bar and upper and lower control arms, with UMI front upper and lower control arms. Lots of squeaks from the front end. Pretty sure it is the control arm bushings. I emailed UMI and they suggested that I make sure all my bushings were greased really good with synthetic grease. Now that the motor is out and it is finally warming up. I plan in doing that. I wish I would have left my stock control arms on. Not a bit of noise when I had all stock setup. When I put the big sway bar on the rear, after a while my rear stock bushings were ruined and started making noise.
