Tfreestyle
- May 24, 2007
Hello all. I have an 86 GN that im restoring that I got from a guy that mostly built it for drag, not so much street driving. Well im going to be driving my car on the street a hell of alot more then on the track so I was debating bumping down the turbo a bit. I currently have a precision T70 that I got here on the forums to replace my blown limit engineering T70 that came with the car. Lately ive been thinking I might have made a mistake not going with a 6776 since im going to be driving alot more on the street. Also since the car has a 3800 stall non lock up converter will that be to much? Im still alittle new to the buick scene and the lingo but here is a quick list of mods to my car...
- built 109 block w/ forged rotating assembly under 300 miles and no track passes yet. BuilT by Archie from GN1 performance
- T70 from precision
- 55lb Siemens (upgrading to 72lb and alky any day now)
- Kenne Bell 70mm Throttle Body and Plenum
- Kenne Bell Fuel Pressure Regulator
- GN1 Performance Front Mount intercooler w/3in Piping
- 3in Cold air intake
- 3in Downpipe with external wastegate
- Single Shot 3" Exhaust
- Headers from Hye Tech Performance
- Ported and Polished Heads
- 212/212 Isky Cam
- double roller timing chain
- Built trans w/3800 stall non-lockup
- ATR Rear sway bar
- Boxed upper and lower control arms
- B-body 12" brakes w/ tubular upper arms
- new Walbro pump with Full Throttle Hot Wire Kit
- Turbo Saver Oil Cooler(need to install)
- Dual ramcharger fans
- Translator Plus
- Scanmaster
- Powerlogger(just installed yesterday)
- 212/212 Isky Cam
- ATR Rear sway bar
- Translator Plus
- Scanmaster
