Silicone Hose (venting)
BFlat
How the heck do you get the hose onto the turbo inlet bell? I’ve tried spit, soapy water and goat semen (okay-that’s not really true) and I’ve used a small screwdriver and a hooked pick that slipped and poked a hole in my hand. I even took the inlet bell off and tried to do it on the workbench. It won’t go. End of vent.
Hose came with the maf tube to turbo. I gave up & went back to what I had. After all I’ve done to it (at least it was a lot for me) I just want to see if it will start.
Measure MAF pipe & turbo inlet ( outside diameter ) go to Silicone intakes and get what you need in the color you want and while you're on there get the good T-bolt hose clamps . They have the inside & outside dimensions listed for what ever you select ....scroll down to the bottom.
