Just wanted to share- couldn't figure out what was causing my car to buck (was happening right before the 2-3 and 3-4 shift, and on the highway.) It did through a code 45 once. Finally found out that a the crimp connector on a plug wire was making intermittent contact. Also bolts on the bottom of Ignition modual bracket were loose. A loose modual could cause grounding problems, right? thanks, Ben ----------------------------------------------------------------------------------- '86 ttype : still a rookie but slowly learning more through use of this site 160 stat, new wastegate solenoid, Red's XP, Caspers thumbwheel, new wires and plugs and oil!
