Is there a certain way this has to be done? I slid my convertor on the first set of splines, wiggled it around a little bit until it slid on further, then it made a "thump" sound and pushed all the way in. Was this done right? Is there a certain place that the notches on the covertor have to be on the input shaft? I bolted the trans up to the motor and there is about 3/8" play between the trans and the flywheel. I didnt put the notches on the convertor in any particular place, I just slid it on. Is this correct?
