What is the minimal slip joint travel I should have.
I just intalled my new driveshaft and I couldn't put it in without taking the cups off the rear u-joint and re-installing them when I got the driveshaft in place.
With the car sitting at ride height, the slip joint comes back out of the tranny just a little over 3/8ths of an inch so there is no binding at rest. My concern is that I suspect that the driveshaft may be a bit too long and I could do some damage to the tranny if the driveshaft gets forced into the transmission too far with diff movement.
I don't want to break off any mains either.
I'd appreciate some experienced wisdom here. Im can have the driveshaft shortened if necessary but by how much. ????
Thanks a lot
George
Thanks a lot
George
