turbojimmy
Supporting Member
- May 26, 2001
I recently put my transmission back in after resolving a torque converter lock-up problem. The converter was not locking (Vigilante 5-disk). I had the trans and converter looked at; both checked out fine.
This time we installed Precision's pump kit and removed the checkball per their instructions. The converter locks up HARD now. That's the good news.
Bad news is that the trans slips bad.
I thought it might be the TV cable but I've adjusted it from one extreme to the other. If I let the throttle set the TV cable it will shift 1-2 fine but the 2-3 and 3-4 happen instantly at light throttle. At mid-full throttle it just slips when it tries to shift above 2nd gear. It won't come down from to 3rd from 4th unless I manually shift it, but 3rd slips anyway.
Tightening the cable (pushing the adjustment toward the firewall) fixes it to an extent, but 2-3 and 3-4 upshifts are sloppy and it will slip as it tries to downshift from 4-3 and 3-2. It will then not want to downshift as I cruise to a stop, I assume because the pressure is too high in lower gears.
I think tightening the cable is forcing a higher pressure that the transmission can't attain normally.
While the transmission was out the only changes, other than the pump tube kit, were:
- new Gbody radiator (possible defective internal trans cooler)?
- new lines spliced in (via flaring and unions, not compression fittings) at the trans (possible kinked line? one of the bends was tight....)
Any ideas would be appreciated. The car hasn't run right in almost 2 years now and I'm really at the end of my rope with this thing.
TIA,
Jim
TIA,
Jim
