SlowGray's "old" dyno sheet on 15psi & Amoco 93-octane...
NCTURBOS
Gettin' back in action!!
Staff member
I was going through some old files here on the computer at work and came across this.
Fairly flat A/F ratio scope considering the lack of tuning on the car. Not bad for a stock ecm, MAF sensor car. :)
K.
72firebird said:
what's with the drop in the horsepower curve?
Right there at approx. 4900rpm is what you're talking about correct? This was a third gear pull and that is when the chip commanded the tcc solenoid to lock-up, and at the same time pull the timing back another 2*. FWIW, I already had the converter locked via a manual switch for the pull.
I also wasn't very happy with the guy running the dyno, even though I was doing the "driving". So this was the one and only pull.
K.
