sm readings how do they look?
tonys87
af 05, l8 32,bat 13.6, int 128, bl134, clt 175, ats 132, rpm 825 850, tps .40, iac 23,cc(counting),pl 1.9, sp 27.3 fuel at line off 42 43 ... the car runs and idles good just wondering if i can improve some numbers, before i took these readings i added about 2psi of fuel and noticed that the bl numbers went from 135 to 133-134
TPS value isn't terrible but.... Generally the ideal settings would be .40 (key on engine off), which should then read .42 (at idle).
.42 (key on engine off) and .44 (at idle) are just as good!
Thats exactly the way i have mine set!
My BLM are 138, does that mean I have a bad tune? :rolleyes:
Ya'll put way too much emphasis on perfect BLM numbers. I think it's a good time to maybe re publish my BLM INT right up. Maybe in the howto section.
