turbobooster
- Nov 12, 2002
I noticed a small leak coming from the area where the speedo cable hooks into the side of the tranny not sure what's causing this leak I'm thinking it's either my speedo cable rounded itself off in time or the small gear in there is stripped what can it be ? Another thing to keep in mind the mph needle is bouncy and doesn't read mph as it should I'm going to b changing out the speedo cable to a new one, what speedo gear is stock for my 85 th200 4R transmission?, I currently have stock tires as well as rear end gears and would like to know of a place where i can purchase what I'm assuming is a 29 tooth gear? Is this something I can do myself or is it a job better left for a transmission specialist ?
