T tajohn New Member Joined May 25, 2001 May 22, 2002 #1 Does anybody run this on a Turbo Trans Am? Where do you mount the alcohol tank?
A automorph Member Joined May 24, 2001 May 22, 2002 #2 In the corner where the air filter sits. Shove the tank in the corner touching radiator. That is where mine is...
R RobR formerly TTA 1387 Joined May 26, 2001 May 22, 2002 #3 Originally posted by automorph In the corner where the air filter sits. Shove the tank in the corner touching radiator. That is where mine is... Click to expand... Mine too. I took out the charcoal canister also.
T tajohn New Member Joined May 25, 2001 May 22, 2002 #4 is the braided line long enough there or do have to add some?
R RobR formerly TTA 1387 Joined May 26, 2001 May 23, 2002 #5 Make sure you tell him its for a TA. It's a lot longer than the GN one.
