Gary Wells
White turbo Buick trailer park trash
- Mar 2, 2002
If it was me, I would go stock powdercoated black valve covers as the GN1's are pretty famous for not installing easy with everything in place in the motor compartment, might be difficult to re-install the kidney plate after the GN1's are in place, they leak (I have heard) around the oil breather caps as the oil breather caps are not exactly a thigh fit, and you have no guarantee that any smog station will certify the smog cert after the GN1 install, and you still won't have the passenger side to turbo inlet hose. If you pretty up some stock valve covers, find & install the passenger side to turbo stuff then you're good to go, and just disconnect after smog. Of course that's just for off-road use only. HTH
