Matt McClung
Hotair guy who owns a I/C
- Sep 18, 2001
I have finally gotten all of the bugs worked out, (injectors dumping fuel, cam sensor problems, egr solenoid filter was clogged making the egr open up at idle, etc...) now that I have fixed all of the problems it now smokes after it warms up at idle. I believe that with all of the fuel being dumped by the injector problem (enough fuel to be dripping from the tailpipes) that the gas may have damaged the turbo oil seal allowing the oil to run into the downpipe. I did not have this problem before the injector problem, and like I said it does not smoke at all when I start it up until the pipes get hot, so I dont think that it is an engine problem and when I give the engine some RPM's the smoke seems to go away but when I let it idle it will start to smoke.
Just wondering what the board thinks.
Matt McClung
Matt McClung
