Sep 4, 2012 #1 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 fresh motor with 1000 miles. After i drive it and it sits a few minutes, it will smoke and i smell oil at start up. I have stock heads but i did put viton seals on the intake and o rings on the exhaust. Could it be a valve seal?
Sep 4, 2012 #2 G GetOwnedVette Active Member Joined Jun 13, 2006 Messages 765 Mine was a bad turbo seal in one of my cars. Always had a little smoke on startup.
Sep 4, 2012 #3 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 take off the valve cover and see if the seals are up on the valve stem
Sep 4, 2012 #4 C Cowboy_Dan New Member Joined Sep 4, 2012 Messages 6 Sounds like exhaust valve stem seals if it only smokes on start up. I use to leave them off on some of the engines I've built.
Sep 4, 2012 #5 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 Cowboy_Dan said: Sounds like exhaust valve stem seals if it only smokes on start up. I use to leave them off on some of the engines I've built. Click to expand... These cars don't have exhaust seals on them unless the machinist cut the guides for them and replaced the valve with some that can be used with seals.
Sep 4, 2012 #6 B blackgn1 Set on TSM Boost Joined Jan 2, 2007 Messages 2,332 I had a puff of smoke from time to time. It was rich at idle. O rings on the exchaust?
Sep 4, 2012 #7 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 blackgn1 said: I had a puff of smoke from time to time. It was rich at idle. O rings on the exchaust? Click to expand... they were in the package, may as well use them.
Sep 4, 2012 #8 C Cowboy_Dan New Member Joined Sep 4, 2012 Messages 6 My bad. I had a T but never got into engine much on it. Guess I was reminiscing back to my v8 days
