turbonut85
Rarely used member
- Apr 11, 2008
I got in the GN yesterday to drive to my shop to install the right torque convertor
and....I get 2 blocks form the house and the stop light turns red, so I start to slow down. That's when I realize I have no power steering and the car is not running!
So here I sit in the middle of one of the busiest intersections in the DSM area and the s.o.b. won't start.
Fast forward past my neighbors coming to push me out of the street, me driving across the city to get the trailer, coming back, loading the car (by myself), and towing it across the city again...(guess that wasn't really a fast forward, was it.) There it sits in the shop. I'm kinda stumped at this time, because EVERYTHING on this car is NEW!! I figure out I'm not getting any fuel...(plugs are dry after cranking). So I unplug the powermaster, and the power antenna, so I can listen for the fuel pump. I can hear it prime when I turn the key on. I pull the schrader cap to hook up a pressure gauge...minimal fuel spray...get the pressure gauge hooked up and turn the key on. I hear the pump prime but the gauge doesn't move from zero. (Keep in mind, EVERYTHING is new---tank/pump/lines along the frame/filter/regulator/injectors etc. Not even 600 miles on any fo them!) After several different tests and such, I finally decide I need to drop the tank and actually SEE the pump running. After all that...my NEW pump runs, but doesn't pump anything!!
It just seems like I can't drive this car more than 1 week at a time before something goes wrong.
So, now I need a new fuel pump. What do you guys reccommend?? I had a Walbro 340 that is now a P.O.S. I have heard they had some problems with some of their pumps....could mine be one of them?? I bought it about two years ago or so. Is there a way to tell if this one was one of the bad ones?? If so, what can I do about it?? (Probably take it in the shorts, I'm sure, but I guess I gotta try.)
I think I'm done with my rant....at least for now...until something else breaks!!
LMK what you guys think... ---Keith
