Rick the pool guy
- Feb 7, 2017
Hey guys just want to share some knowledge with you working on a 87 GN today and it had symptoms of a vacuum leak( high idle iac 0 etc) so start looking at vacuum lines plenum gasket every possible item we checked
As we were replacing the throttle body gasket we noticed the throttle blade was slightly bent
Creating symptoms of a vacuum leak,so we bent the blade back straight as we could put it back on using the same gaskets plenum etc and iac went back to normal and idle dropped to normal range 850/950 .
1st pic you can see light coming through
2nd slight bend.
2nd slight bend.
