- Jun 18, 2001
So tell me about TV adjustment and low pressure... An incorrect adjustment in which direction will cause low pressure? Does the photo above support this (with the cable housing showing so many ridges?
The way it looks at the throttle body is a bit irrelevant without knowing the condition of the cable. The idea is to have the throttle valve in the transmission all the way open at WOT. When you pull the cable all the way back through the fixture, then crank on the throttle, once the throttle valve reaches it's maximum travel in the transmission, the sheath should click through the detents in the mount.
But it could be stretched or damaged, which is why the appearance up top may or may not mean anything.
Have you pulled the TV cable from the transmission yet? Is it even connected to the throttle valve?
