Just got a new turbo car, and i decided to flush the brake system since the fluid was black.....well, i bled three out of four using a vacuum bleeder, then i had to get a new front pass caliper because the bleeder screw wouldnt bleed and i couldnt find a replacement. Anyway, i finished bleeding them, started the car, and the pedal was much softer than it was when i got the car. So i bled the front and rears three more times (2 with vaccum, then manually), got no air and figured it would be good....nope, pedal is still soft. The master cylinder is not leaking and i didnt mess witht he vacuum at all to the master cylinder. what else could it be???
