meanchicken
gallo vicioso
- Oct 6, 2007
Howdy,
PowerMaster system.
Having an issue with a soft peddle the my brake light coming on when applying the brakes. Also noticing that my fluid in the reservoir gets murky and dark pretty fast....within days....of emptying it and refilling it with fresh fluid.
A few times now, when I noticed the light and soft peddle, I would change out to fresh fluid. Initially the issue would be solved, but within a couple days it would start coming back.
I know the accumulator ball and pressure switch are good.
Bad Master Cylinder or bad pump?
PowerMaster system.
