solid roller lifters
jpwalt1987
Hey guys I am looking for some Crane or Crower sheilded foot solid roller lifters. This is for a 109 block. I have some Comp hyd roller lifters that have 1000 miles on them for possible trade or something also. Let me know what you have and how much. thanks , jeremy walters
I have the cranes new in box, but they are limited to 540 lift depending on the base circle of cam. But they have worked on a 224 cam from PTE
The cam has .560 lift with a 1.60 rocker and .010 lash. Not sure what size the base circle is or what lobe lift is. I will have to measure it.
norbs, i called and got a copy of the cam card. here are the specs:
base circle- intake:.910 exhaust:.920
lobe lift- intake:.35008 exhaust: .34949
hope this helps, jeremy
I took some measurements,
pte hr-224-110 cam hyd roller
base circle=1.080
lobe lift=.350
The lifters did work on this cam no problem. I think they will work.
I have a possible trade in the works. I will repost if it falls through. thanks, jeremy
