My 87 GN has a problem when I pass a car and go into boost at about 5 to 10 pounds it surges and poops back through the intake.It seems ok under boost it is when you let out just a bit to slow down then speed back up.Only thing I have changed in awhile is I went from a 3"MAF to a used 3.5"MAF sensor I bought off a e-bay.I can not put the 3" back on because I sold it.I have a couple of DS files if anyone would like to look at them!Also can I attach a file on here?
Chip file #M5092Y22
Translator+ 5.0
switches on on off off
knobs 2 0 0 0
The number on the MAF (on the plastic)is 94143 8240 2 on the tag (bar code)is 82410098778
Thanks for any help!
Chip file #M5092Y22
Translator+ 5.0
knobs 2 0 0 0
