Scott, I would trust you to do welding, since you've never had a callback and you have more than been an honest guy here on this forum going out of your way to help everyone. I was so impressed by all the concern/help you gave everyone on the LED Tail lights. I may be taking off the driver's side header of my '87 Grand National this summer because it has that famous crack in it My questions: How much do you charge for this service of welding it and installing a brace? And do you bolt the header flange up to a flat surface BEFORE welding it? Do you have any guarantee on the weld? Richard Clark informs that the cracks always reappear sooner or later. What's your opinion on that? Do you use TIG welding for this procedure? Could you let me know soon on this? I DO have to get my header welded...it's a matter of when I can take it off. I'm swamped with other stuff but WILL get around to doing it. (sigh):frown: So much to do...so little time. And to top it off, I keep getting older for some reason or another. Lots of questions but need answers)
Bruce '87 Grand National
Thanks for the kind words!
Here are the answers to your questions.
1) It really depends on how bad it is cracked! I charge $75.00 to re-weld the crack if it's not too bad or gobbed up with other peoples weld attempts and obviously more if I have to spend more time on it.
2) YES I clamp the header down all over the flange area before welding to avoid warpage.
3) Gauantee? Again it depends how badly it is or if it was all gobbed up with welds before. I pretty much can garauntee my work as I'm yet to have someone un happy with my welds or warpage.
4) Richard Clark is thinking about how people "Used" to do it. There is a "reason" why they crack, I fix that problem! Maybe someone that had me weld up there header might see this and chime in as to my work quality, and if they ever cracked after I weled it up.
5) I use a MIG and grind away old welds. I don't just plop it on a table, weld it up and send it back. I do take my time as if it were mine.
NOTE: Is your header Stock? Reason I ask is I may have one here that is all ready to go and could just swap you out for your cracked header..
Scot W.
