SP 204/214 Cam , I like it !!
KWIKR 1
I have a new rebuild with the SP 204/214 cam . I engine orig had a Crane 212/206 Roller before putting in the SP cam in . I took out the roller and sold it to fiance the rebuild (long story) . Well all I can say is this cam ROCKS with my combo . Has a great bottom-mid end and pulls like Frankenstein on the top . I was a little worried about putting it in after doing a little research . A lot of people do not think cams with larger exhaust durations work in turbo cars .I was a little tight for cash so I thought I would give it a try. At $150 (Canadian) I figured why not. I don't know but it sure as hell works in mine . After coming home tonite from blowing the rear tires up in smoke from a 45-50 mph roll on at 19 lbs of boost (nice cool crisp nite:)). . It sure put a grin on my face .
I had a old buddy in the car . and his comment about the cam was " sounds like a stocker - goes like a fu#ker" . He said it not me :D .
I have one of those and its big brother 208/224 sitting here to try later. You can smoke all the doubters:D
Man I'm hoping that cam works with my current combo, after my old 313b cam went, I am also getting ported and polished big valve stock irons so i won't be able to tell a back to back difference. I'm glad it worked for you, I debated for weeks on what cam and you just reasured me that I made the right choice.
Once you get the cam in it will take a little a while to get to "know it" or "the feel of it" . It has " A Real Sweet Spot" in the mid/upper range . You'll find it :D .
what is the part #?
will this work well on a car with gn1 heads? what is the # and who can i get it from?
Sealed Power EP2 Cam - #CS-1016R , Lifters- #HT-969 . . Any automotive shop should be able to order Sealed Power/Federal Mogul parts . Enjoy :D .
maybe some track results before we get too excited??
it's just a cam.....
I BELIEVE IN THOSE TYPES OF CAMS AS WELL.
BIGGER EXHAUST THEN INTAKE TOTALY MAKES SENSE
I WILL BE PUTTN ON IN WITH MY NEW MILL.
This was from 3 weeks ago . It was a very cool day and I was suffering from street radial traction problems and a very bad mid track miss/stumble : 1/4et- 13.06 , 60 FT - 2.330 , 1/8 - 89.07 , MPH - 114.46 .
Original stock cam installed in 1987 on the assemblly line - runs 11.50's @ 116. What else could you ask for :D
IMO, Unless your shooting for 10's the stock cam is great with the right tire.
