Spark plug gap when spraying methanol & higher boost.
Hey guys,,
I am curious as to your spark plug gap when you are spraying methanol & higher boost?
Do you gap your plugs smaller than .030 on a typical set-up?
Also, do you guys usually add an MSD box to increase the spark output?
I used the search feature & came up w/nothing.
Just to give you an example of how small some people go, I'm running my spark plug gap at .022". Not that I have to run it that tight to prevent ignition missing, but the tight gap lessens the load on the secondary leads.
