car was starting and running fine and now it wont start. I unhooked the ecm to acharge the battery then put in my new TurboTweak chip and can't get the car to start. The last time I drove it, it was running rough and I just assumend it needed to be tuned in. I was reading past posts and my injectors hold pressure after the car is off and the plugs are wet and black. I cleaned and replaced three of the plugs and no change.
I had the same probem last year with the plugs fouling out and the car wouldnt start so I took them out and cleaned them and the car started right up, but the car would not run strong like it wasnt hitting on all cylinders. No such luck this time though
Possibly the injector harness is shorting out or being pinched and grounding out?
Cam Sensor?
Need new coils in my Type II?
Any help is appreciated
Cam Sensor?
