Spark Plugs
Not sure on your mods but it would probably be safe to recommend AC Delco CR43TS gapped at a tight .035. This will be your best bet.
When you start moving really fast you can look into a bit cooler CR42TS. Also I like the NGK UR5 plug. Gap may get a bit tighter when you start running higher boost levels, etc.
I run AC Delco CR43TS gapped at .035 - work great for me.
They are a bitch to change though !!! :mad:
